Dowel Plancment
Hi Guys, Can you please help me about the dowel placement, I am using MV Foundation library 24.0919.
Dowel Placement
  • Dowels holes: 16 mm deep, 8 mm diameter
  • Doweling is 32 mm apart or multiples of 32 mm..
  • Dowel spacing: 2 in front and 2 in back, then generally equal placement in increments of 32mm shortest spaces if needed should be towards front.
  • 10” & 14” cab: need only 5 dowels
  • 16” cab: 6 dowels
  • 18”, 22” 24” : 7 dowels
  • Stretchers, Nailers & Toe Kicks traditionally have a depth of 96 mm with doweling at 32 mm & 64 mm.
