Draw Invisible Wall
Is there a way to draw an "invisible wall" like in v67? Sometimes I need to drop cabinets in an open area where there are not walls. In v67, it would just draw a line as a reference to drop the cabinets. In the newer version, you cannot draw a wall with no thickness. There will always be a wall drawn. I know you can turn off the AutoCAD layer that the walls are drawn in, but it would be nice if you did not have to turn on and off layers.
