When machining DTC Smooth draws the product prompts 13mm and the CNC drills 13mm for 5mm diameter holes but when using a Blum Merivobox draw the prompts are still 13mm but it machines 5mm fittings at 16mm deep, I've looked in Design Data and Global File they all say 13mm yet it drills that specific draw at 16mm, is there somewhere I haven't looked where it is being overridden?
