Drawer Base Edging on Fronts
Would it be possible to get a variable setup to tell toolbox to edge the front edge all of the bases of metal sided drawers like grass/blum etc. I assume adding a global variable and changing the front edging of the drawer bases to be controlled by this variable.
The reason for this is that it seals the front of the drawer bases and makes them more moisture resistant and means if there is any small chipping from the cutting processes that they can be removed by premilling on the edgebander.
Thanks
