Drawer Front Set Screw Holes Machining
Our shop recently came across this issue after updating to 24.1127 where our drawer fronts were receiving holes for set screws when we previously did not have them process on the CNC. We checked through all of our global settings and found that there are two separate checkboxes to toggle this:
1. Drawers/Rollouts -> Global Variables ->  Drawer Box Variables -> Wood Drawer Box Variables -> Drawer Box Construction Variables -> Drawer Front Set Screw Holes
2. Library Construction -> Global Variables -> Cabinet Construction -> Cabinet Door-Drawer Condition -> Dwr Front Set Screw Holes
Additionally, in the edit part in 2D, it shows that its boring a .375in hole, but it drilled all the way through our drawer fronts on our project. Definitely make sure that both of these are turned off if your shop does not machine for them.
