When you draw a polyline and right click on walls and choose "Select polyline path for wall" and MV draws the wall and applies the dimension over the wall, the dimension endpoints are connected to the wall and cannot be moved like it could when I was using MV and AutoCAD. So if you try to highlight just the dimension to move it up say 5" for a wall thickness, the wall layer highlights as well and will move with it. Is this a setting in BricsCAD or Microvellum that can be changed?
