Drill Distance Past Part
Hi,
I am trying to adjust the depth that our THRU bit drills past parts. I thought that this was something that was easily adjusted via the Globals under machining (see attached image). After adjusting this Global, the bit is penetrating .02" through the material (not the 0.15748" specified).
Am I missing something here? Is there a different setting that controls this?
Thank you in advance,
Jake
