Dropped Routing When Copying Machining
I am having an issue when trying to copy machining from one part to another. I am using the 2D part editor, copying all the machining using AutoCad copy, then pasting it into another part in 2D part editor. This works fine for all the drilled holes but it is dropping the routing, see attached. The only way I can get this to keep the routing is I reverse direction of each routing or otherwise modify it after it has been pasted. I am wondering if there is a better way to accomplish this, there is enough machining to copy, not all the same, that i would like to streamline the process but not enough to justify the time to make a custom machine token. This machining is for a unique field joint design that is specific to one project. Parts that the machining is being assigned to will be generated by SMA, all will be different lengths, some will have curves. Is there a better approach I could take?
