I am wondering if there is a way to prevent MV from assigning the same program number to different sheets when processing a work order where parts are being sent to multiple processing stations. We often have releases where there are plywood parts for stud walls along with cabinet parts, the plywood parts are send to a processing station with tabbing enabled whereas the cabinets parts are sent to a processing station that uses onion skin. We process both in the same batch so that we have one report showing all the material being used. I would like to change this as it can be confusing when reading the nest report, like materials are no longer grouped since the report is printed by program, every other page is a different material.
If there is another way to accomplish the paperwork being in order I would gladly entertain it.
Thanks.
