Currently, the Edit Multiple Product Prompts tool is one of the biggest time-savers in Toolbox for batch-updating dimensions, construction methods, and custom properties across cabinetry. However, walls are completely excluded from this workflow forcing us to open and modify wall prompts one by one.
Extending this spreadsheet-style batch-editing functionality to walls (or adding an Edit Multiple Wall Prompts command) would eliminate a massive drafting bottleneck and reduce errors on multi-room and commercial projects.
The Current Pain Point: Since walls act like specialized products under the hood, having to edit them individually feels like a major gap in workflow parity. On larger commercial jobs, multi-unit residential projects, or complex custom homes with dozens of walls, late-stage architectural revisions turn into repetitive clicking. Right now, if an architect changes a spec across a floor plan, I have to manually open the Wall Prompts window for every single wall segment to make the update.
Where This Would Make an Immediate Impact:
Architectural Revisions (Heights & Thicknesses): When an addendum changes ceiling heights across an entire floor (e.g., bumping 96" walls to 108"), or switches framing from 2x4 to 2x6, we have to touch every wall individually. Selecting 30 walls and updating Wall Height or Wall Thickness in a single grid would turn a 20-minute chore into a 10-second fix.
Rendering & Presentation Prep: Before generating 3D views or client elevations, we often need to standardize wall colors, drywall textures, or visibility settings across a room or entire job. Batch-editing makes cleaning up room aesthetics effortless.
Visual QC & Error Reduction: Clicking into walls one at a time makes it way too easy to accidentally skip a short return wall or mistype a value. A tabular view gives us a quick visual sanity check to verify that every wall in a room shares the exact same height, thickness, Z-offset, and material parameters before releasing shop drawings.
Zero Learning Curve: We already know and rely on the Edit Multiple Product Prompts UI—especially saved column lists and the "Redraw on Close" toggle. Applying that exact same interface to walls keeps Toolbox consistent and intuitive.
If you’ve ever had to manually click through 50+ walls just to change a ceiling height or paint color, please give this an upvote!
