Sometimes, when we are about to nest and are in the Processing Center, we discover that the wrong material or incorrect edge banding has been assigned. In such cases, we need to go back to the drawing, fix the issues, and redo the entire process. It would be great if it were possible to edit the material and change it, as well as edit and assign the correct edge banding while reviewing them in a list format within the Processing Center.
Example: Changing stretcher from 19mm White Melamine -> 19mm MDF
Being able to assigning Edge Banding (if missed) - EB Width 2 and EB Length 2 (2 sides) or EB Width 1, 2 and EB Length 1, 2 (4 sides) and being able to choose the right edge banding.
Example: Assigning 1mm white edge banding to the top and bottom, and 1mm finished edge banding to the front side.
