In Microvellum Toolbox 2020, it appears that the Global variables (G!Elev Dim Offset Baseline and G!Elev Dim Offset Vertical) that controls the offset distance the elevation dimension is from the cabinet does not work. I have changed these Global variables and the elevation dimension location do not change. I cannot find where these elevation dimensions are controlled. I couldn't find any 2D Drawing Tokens that creates the elevation dimensions.
