Elevation Section Across a wall
I apologize if this has already been covered, but I couldn't see this anywhere.
Currently there isn't an option to create an elevation section for all the cabinets across a wall - at least as far as I can tell. It would be great if you were able to do so, I know you can individually elevation section through a cabinet, but if you have 20-30 products on a wall individually slicing them is quite a lot of work & time consuming. You can section a wall as a plan or cross section currently we are just missing the elevational section.
Thanks
