Parametric equal groove spacing
Hi all,
Could an official method be added to create door grooves that have equidistant spacing across the whole door rather the way it's currently done via the D! spreadsheet? (Equidistant grooves in the middle but variable distance on the outside)
I couldn't figure out how to do this via the D! spreadsheet since it relies on the width of each door but made a modification to the MV Profile Door subassembly. I changed the Distance Between Grooves prompt to =Width/(ROUND(Width/72,0)) where 72 is the target groove spacing and Groove Remander Panel 1 to =Distance_Between_Grooves-Offset_X_Panel_1. No idea what other interactions there could be with other door configurations but it worked for this particular circumstance.
So something like that would be good to have.
Thanks
