Extruded Plates not Following Construction Path
Hi all,
I am trying to extrude using a radiused construction path. Even though my plate and my stud have the same base point, my studs are following the construction path but my plate is not. I've tried messing around with offsetting the base points of my construction path, but that does not seem to help. Any ideas would be appreciated! Thanks!
