Face 6 Cutting Edge
Hi,
Our workshop have reported that when we run a specific part that required a 11.8mm channel for LED strip both sides.
That on face 5 it comes out fine, but on face 6 the code goes awry!, for some reason, the cutting edge flips from LH Cutting edged to RH meaning we get an 11.8mm perfectly trimmed rectangle, rather than a 11.8mm channel, the machine tokens for both are exactly the same, and if I switch the 6 for a 5 in the token as a test it cuts out perfectly.
Has anyone had this before, is it a corrupt file, Is it something that has always been the case, I just didn't hear about it, Any advice greatly appreciated.
Many Thanks
Marc
