A coworker and I found an issue with FDM spec groups - How do you update the current spec group in the 2D Machining Tools menu? We tried closing the menu, opening Advanced Project Setup to select and set a spec group as current, then reopening the 2D Machining Tools. Didn't work. It seems we need to be able to set a spec group in the 2D Machining Tools menu, but that's not possible.
Ultimately, he needs to add a few sheets of material to manually adjust for grain matching in Composite. Simply COPYing a nested sheet won't work - right?
