The image below shows some improvements that would really help speed up working in a composite drawing. A big one that I would really like to see is the rotate part to always rotate 90 degrees clock-wise (you could essentially rotate it a full 360 by clicking on it 4 times). Currently, it will rotate the part 90 degrees one way and then revert back to its original rotation the next time you select the same part - let's keep it going 90 degrees each time it's selected.
I understand AutoCAD commands like MOVE, ROTATE, COPY, ERASE can all be used in the composite, but there are added features and functionality to the tools MV has developed that make working in the composite easier. These improvements would make things even better!!
