I would like the ability to Mass Edit one Comment Field without overwriting the other two Comment Fields in Overdrive. Currently, when you Mass Edit the Comment Fields, you overwrite all three Comment Fields. If you don't understand that this will happen, you could lose important information from the other Comment Fields costing you time for additional updating. So, I would like to be able to individually update each of the Comment Fields. I can see two ways to accomplish this. One way would be to allow us to open each field individually, which would mean that I need to click on and edit three fields in each Product. Another way would be to open all three Comments Fields as you currently do, and add a check box to check for the Comment Fields I want to overwrite.
This idea/issue was brought up in the 2026 Q1 Microvellum Roadmap Focus Group, but I couldn't find anything on it in the Community. So, I wanted to add the idea in as I see value in being able to mass edit a Comment Field without overwriting the other Comment Fields.
