Feature Request: Ability to rotate top rails in cabinets for face frame construction.
One of the things that we see and do as a regular assembly method for Face Frame cabinets is to either use the triangular corner blocks or simply rotate the top rails to run front/back instead of left to right.
In our case we do dado these rails into the sides then as well but then we simply use butt joints at the front/back.
