FEATURE REQUEST: Add a User Editable Field to Materials for Project Material Callout Numbers
Add a user editable field to the material/edgebanding/hardware libraries for material callout numbers. This would be used when printing reports to show the material callout numbers uses on a Project without having to make the material Project Specific. This allows the reports to print with material callouts that match the shop drawings. The reports could show "PL2 - Wilsonart 7054-60 Wild Cherry, Matte", H10 - Hafele 280.11.107 Metal Shelf Supports, Nickel, or PL1EB - Frama-Tech F7223 New White, Matte.
If the field is blank, the report would ignore the field and just print the material name. This would allow the reports to print as they do now for those that don't choose to use the material callout numbers.
