FEATURE REQUEST: Add Machine Token UI to Edit Design Data
If you've ever worked in the spreadsheet (Edit Design Data) and needed to add a machine token, then you understand the frustration of not remembering what parameters 1-9 are for each token that exists. The spreadsheet is not user friendly when it comes to adding machine tokens for that reason alone.
A lot of times I find myself bouncing back and forth between Edit Design Data and Part Properties when developing products. It's inefficient.
It would be super-amazing, fantastic, mind-blowing - all the things - if we had the ability to access the Add New Token interface with all the parameters in Edit Design Data!
You could take that a step further and do the same for Draw Tokens and others....
"Oh, the thinks you can think, if only you think!" - Dr. Seuss
Pretty, pretty, pretty please - with a cherry on top?
