There are many products in the library that need a different cut section location by default. One particular product would be a 2 Door 2 Drawer base. The current cut plane for a section is 1/4" less than the mid-point of the product's width (unless you manually change it). Well in the case of a 2 Door 2 Drawer base, this cuts right through the drawer division and leaves a funky interpretation of a drawer box.
Having the ability to add the following variables would be great for setting up the default cut planes so you don't have to change any of that.
Section_Plane_Cut_X for cross sections
Section_Plane_Cut_Y for elevation sections
Section_Plane_Cut_Z for plan sections
James Drury
Technology Advocate
MICROVELLUM SOFTWARE
Vimeo
