Feature Request: Better information on error and popup messages
When processing cabinets it would be nice to have better information in error or popup messages.  In this example there is an error in an activity token.  It tells me it in an “N” workbook but it doesn’t specify which Parent Subassembly I should be looking into to find the issue.  This becomes frustratingly hard when using a product starter type product with multiple Subassemblies that need to be added and modified so tracking down where the issue is becomes difficult and time consuming.
I would like to request the same better information for other standard Microvellum commands as well.  When using the “Associate Products to wall” command the first input simply says “Select Objects”  It doesn’t say Select the Wall you want to reference.  So in teaching a new person on the system if becomes difficult because we are constantly preaching to read the command prompts but then the command prompt isn’t clear or simply doesn’t help.
