In older builds like Build: 21.1.0519.641 SMA/SMT had the ability to apply
logically apply Grain Direction based on material type and overall Part Size (width/length). In the newer '22 builds that function has been removed.
When building a multi piece desk that may be U-shaped or worse the width/length appears to be assigned to parts based on the their overall rotation and location in reference to the global 0,0,0 point. That is fine but then when you start trying to analyze and process the parts the system try's to force them into sheets based off the width/length and doesn't appear to allow them to rotate. This is made worse when using plywood or something with a grain direction that you would also want to have oriented based off that.
Having to manually manipulate parts and apply or override grain direction in the Part Properties or in the hidden section of the spread sheet get time consuming and tedious. Example: I am currently working on a 3 Unit U-Shaped desk that has 50+ parts for every unit. What feels like half of those parts need to be manipulated to get them to optimize in the work order and on the sheets correctly.
