Feature Request: Built in variable to reference maximum material size. (Width/Length)
Similar to how we can add the term _Thickness to a material name to get the actual material thickness; I would like to see us have the ability to have _Width and _Length to reference the maximum sheet size whether it's the Width/Length.  This would allow for us to add new formulas and options to then swap materials when we hit a maximum size or also create warnings to identify and warn people when they have exceeded the maximum part size and need to address the issue.
M!Wall_Mounted_Shelving  =  Material Name
M!Wall_Mounted_Shelving_Thickness  =  Material Thickness
M!Wall_Mounted_Shelving_Width  =  Material Max Width
M!Wall_Mounted_Shelving_Length  =  Material Max Length
