It would be excellent if there was a machine token that indicated which is the bottom of a cabinet back panel.
This could just be an additional 3mm deep 3mm drilling token on the bottom edge or something similar.
This would save needing to get a tape measure and measure where the shelf holes are located top & bottom to determine which way up the back goes
