Feature Request - Change Material in Processing Center
I know that it could be very convenient to be able to change the material for a part in the processing center.
What we run into on smaller jobs is I would like to switch the following materials
2 side Mel (For Drawers only) ----> 2 Side Mel (All parts)
1 side Mel ------> 2 Side Mel
Lam/Backer .75 PB -----> Lam/White .75 PB
Lam/White .6875(Door Mat) -----> Lam/White .75 PB
See on a smaller WO on a job I can save nearly 4 sheets of material. This is huge for small runs.
I realize there are other ways to achieve this, but I'm very used to BlueCell where you can just switch one material to be another at the last second whenever you see there aren't many parts on that material.
I would like to try to avoid changing the cutpart component for a project just because I've decided to run 2 cabinets instead of 50.
Thoughts anyone?
