Feature Request: F Workbook in Portal Library Updates
We use the Portal Plug-In and after a library update the F Workbook currently does not get transferred to the local configurations. Thus, any new hardware that is now located in the F Workbook is not available for our users, making the library update feature useless for us.
Problems
- Foundation library changes are not propagating to end users.
- These force manual workarounds or prevents important updates from reaching the field.
- It breaks the expected behavior of centralized library management though the portal.
Expected Behavior:
When a library is published through the portal, the F Workbook should be automatically included (along with the other library components) so that template level changes are distributed to all local users.
Steps to reproduce:
1 - Make a change to the server F Workbook
2 - Use the portal to Update Library from Server
3 - Check the resulting update package on a local user machine
        - F Workbook changes not applied
