It doesn't happen very often, but it would be nice to have more granular control over the display.
- add a prompt to the Wizard: Face_Rendering_Finish
- within the Finished Faces subassembly (and related subs), change the Rendering_Finish prompt formula from:
=IFERROR(IF(L!Rendering_Finish=0,INDIRECT("W!"&MYCATEGORY(L!ProductCode)&"_Rendering_Finish"),L!Rendering_Finish),INDIRECT("W!"&IF(VLOOKUP(Bay_Position,LookupTableBayPositions,8,TRUE)="U","Upper",IF(VLOOKUP(Bay_Position,LookupTableBayPositions,8,TRUE)="T","Tall","Base"))&"_Rendering_Finish"))
to:
=IFERROR(L!Face_Rendering_Finish,IFERROR(W!Face_Rendering_Finish,IFERROR(IF(L!Rendering_Finish=0,INDIRECT("W!"&MYCATEGORY(L!ProductCode)&"_Rendering_Finish"),L!Rendering_Finish),INDIRECT("W!"&IF(VLOOKUP(Bay_Position,LookupTableBayPositions,8,TRUE)="U","Upper",IF(VLOOKUP(Bay_Position,LookupTableBayPositions,8,TRUE)="T","Tall","Base"))&"_Rendering_Finish"))))
I don't know if this would mess with the upcoming update to the rendering materials that was mentioned in the 2026 Q1 Roadmapping, and perhaps there's a more elegant solution (à la within the lookup tables).
