Formula Driven Materials are great, but after using the FDM spec groups for a while now, I've added a prompt to make life a little easier. I know it's not that hard to go in and edit the lookup tables, but I really don't want to if I don't have to.
Let's say that you have Material 2 spec'd with a .6875 PBD core and VG laminate exterior, liner interior.
This (in imperial) adds up to 0.73875" which is not the actual thickness of the material that showed up at the dock or was laid up in-house.
Just above the Material_##_Thickness prompt, I've added Material_##_Thickness_Adjustment prompts and added that value to the respective thickness formulas.
Most of the time, that adjustment value stays at zero. Sometimes, I'll go put a mic on some sheets and have to add or subtract quite a bit from that 0.73875"
