FEATURE REQUEST: FILTER Function Added to Spreadsheet Functions
I was really hoping that the Excel FILTER function was a recognized function for MV spreadsheets. Unfortunately, it is not... poop. I can really see some great use with this function and the 2D Drawings subassembly.
Imagine having a lookup table (or tables) with all your drawing tokens then using the FILTER function to populate the parameters for the drawing tokens based on certain criteria... that way all you would ever see are the active tokens that YOU want without having to get too crazy with formulas to turn them off or on. AND you wouldn't have to have a bunch of zeros listed under the tokens. It would be AMAZINGLY efficient to build up that sub to work in limitless situations.
JEREMIAH - this is what you need for what you and I have talked about with your drawing tokens.
