FEATURE REQUEST: Find Where Scrap was Used in a Nest
It would be great to be able to see where a scrap sheet was used in the Microvellum Work Orders. This would allow a user to find a scrap sheet within the work orders in case you re-edit a nest that changes a scrap sheet size. This would allow you to quickly find any work orders that also may need to be re-nested due to the scrap sheet size, etc. As nest data is stored in a small database file in each work order, I would suggest that Microvellum add a column to the inventory that specifies what work order the scrap was used on. Some other options for this field would be that the shop used the scrap or the scrap was trashed. This should allow a quick search for if and where a scrap sheet was used.
