FEATURE REQUEST: Flatshot Parameter Descriptions
For most 2D drawing tokens (DRAWLINE, DRAWTEXT, DRAWRECTANGLE) the parameters in Part Properties specify what goes in each field (Start X, End X, [Text Style]|[Text Alignment], etc).  It would be helpful to see the same for the FLATSHOT metafile token.  If it could describe the options inside each parameter, like Machining Tokens do, that would be even better.
