Feature Request: Highlight entire row of subassembly that is selected
I know that when accessing the subassemblies from the main cabinet prompts the selected subassembly has bolded text.  What we would like to see is that the background of the row for the selected subassembly be highlighted a unique color similar the picture below.
What we have noticed that newer users are not used to needing to Left-click to select the proper subassembly.  We are seeing that they want to simply Right-click on top of the subassembly they want to select and then make changes.  (Thick using the Pick-Corners option to adjust subassembly locations)  In at least one case we found that someone simply Right-clicked on top of the subassembly they wanted to delete; and then deleted the Cabinet Carcass instead and didn't even notice this change.
