FEATURE REQUEST: Metric Accuracy to 0.01mm for Hardware Machining
Microvellum Version 6.7 Metric Spreadsheet Accuracy used to be 0.01. Now on Version 7 the smallest we can go to is 0.1. The 0.01 accuracy really helped troubleshoot hardware machining problems and working with associated hardware in general easier. In version 7 all the X,Y,Z coordinates get rounded so you can not really tell which axis is going into wood and doing the machining, since 22.99 or 23.01 get rounded to 23. For some reason, the Accuracy does not apply to part properties, only the spreadsheet. So it will be 22.99 in part properties, but 23.0 on the spreadsheet. This was not an issue for Version 6.7, Please see attached for reference. We would greatly appreciate a tighter accuracy in the spreadsheet for this scenario.
