I'm sure this would be a big undertaking, but it would be helpful if the 2D Drawing Tokens (and Virtual Routes, etc) were not on the "Prompts" tab. When moving prompts around, it can be cumbersome to make sure that you are not messing up any of the stuff far out to the right that is un-related to the prompts themselves.
Generally, keeping things together that belong together and removing things that don't makes operating MV much more streamlined, in my opinion. For instance, I loved when the Machine Tokens changed so that all tokens could fit on the Cut Parts tab on the same row as the part they associated with. I wish that the Hardware (H!) file worked like that, with all hardware machine tokens on the same row as the hardware part itself. It would make maintenance much easier.
