Feature Request: Room Prompts
It would be great to have the ability to set up Prompts that are like the Global prompts but for the room specifically. The spec groups do most of the heavy lifting and paint with a broad stroke which is nice it almost every use case. Some times your have an odd room or two that have different depths from the rest of the job and could be from each other as well. This would also allow for the use of custom lookup tables and other fun things that don't need to be project or library specific.
