It would be helpful if Microvellum notified you with a confirmation dialog box notifying you that the material you entered is a duplicate material name. This would be helpful to prevent issues within Microvellum when you have two materials with the same name. Microvellum can use information from both materials without you knowing which one was referenced creating lost machining, etc.
