When you draw a part with 2D Draw Part uses the default routing tools even if you have material machining overrides. It would be helpful if a part is on a material with a machining override that the border routs would use the tool specified in the material override at the correct depth. This would be helpful for adding cuts that cross the border rout at the same depth, so the rout would be included in the border rout rather than a separate rout.
