FEATURE REQUEST - Update Library through Library Designer from .SDF file
Library Designer has become a very powerful tool for mass changes and manipulations.  It has also allowed all of the cutx information to be housed in an Sequel Database which opens the door to additional avenues of change through queries and find and replace for those with knowledge of sequel.  Changes through the Sequel Databse are visible in Library Designer, but will not "Commit" because Library Designer doesn't think those cells have been updated.  Could there be an additional button or function that would allow all cells to be written back to the Factory Database?
This would allow mass changes to the Subassembly Fields, reordering of prompts in mass, custom queries, and endless other possibilities for the manipulation of cutx files.
While I realize one could do a lot of damage if the data in the Sequel file is mishandled or disconnected, every piece of information about library designer that I have seen emplores the user to make a copy of the Factory Database before updating Library Designer.  Should the user practice safety and make a copy, no issues should arise.
