FEATURE REQUEST - Update Work Order Summary - Sheet Stock Quantity after Manually Adjusting Nests Removes Sheets
When I make manual changes to the nests in the Composite Drawing, I would like the Sheet Stock Quantity on the Work Order Summary to update to adjust to match the quantity in the drawing. I have run into many times that after I adjust the nests in a Composite Drawing, reducing the quantity of sheets required due to radius parts, that the Sheet Stock Quantity does not change on the Work Order Summary when the G-Code is re-written. Currently, I edit the sheet quantities using a PDF Editor, but it would be much more accurate if Microvellum updated the quantities when re-writing the G-Code.
This could possibly be updated already, build 24.1.1105.641. We are working on updating AutoCAD and moving into the Foundations Library to update further. The new nesting feature should also help with this.
