Currently, when analyzing custom products from the Solid Model Tools, the parts come in using similar BASE POINTS. To an extent I understand that this is probably the easiest way to tackle the analyzed parts. However, there are times when I will use the Solid Model Tools to create a quick product that I will then add parametric formulas to, and I find myself having to adjust part rotations so they match parts that are found in library products. Throughout the library the most common rotations are:
However, products created using the SMTs use a lot of other rotations that are not common with the library product parts. It would be great if analyzed products used these rotations as their reference.
James Drury
Technology Advocate
MICROVELLUM SOFTWARE
Vimeo
