File Drawer Panel Thickness
I am not sure if this is an issue for others, but the default file drawer panel thickness was set to 3/4" meanwhile in our production it should be 5/8", I would like to see if we can change it based on that so that it will show correctly in work order reports as well as the shop drawings.
Also any suggestions on how to make the perfect fit for file drawers if they are not fit the current slot? Like auto adjust the height from 7" file drawer to 6" file drawer if the 7" is not fit.
