Fixed shelf dowel depth at a Division
Hello
When two fixed shelves are separated by a division the dowels on the fixed shelves interfere with one another.  I know about the offset dowel option in the global variables.  The issue I have with that is the offset creates the need for the part to be flipped since the face drilling does not go through the division.  Is there a way to change the dowel depth on the fixed shelf?  Or, is there a way make the offset holes drill through?  I have not been able to find a solution so far.  I am on Toolbox 2024 running the 49.1 Imperial Library, build 24.1.219.641.
Thanks for any and all suggestions you are willing to give.
