Force sheet size for work order nesting
Hi,
I have a material 19 WD1 Plywood 1s, a stock material from Toolbox under Veneer Plywood that has both a 4'x8' and 4'x10' sheet size. I only want to nest my job on 4'x8' but it always uses the 4'x10'. How can I, without copying the material and then having to change all my material callouts, get it to only nest on 4'x8'.
Thanks!
