We have different door profiles that are a difference of .75" and 1", and those require different hinges. They are both Blum Full Overlay Inserta hinges but the part # is different for the 1" thick door hinge. How can I add a formula to the hardware to switch between the hinges when the door profile is different?
We currently set up our Project Wizard to select door profiles there, and everything changes as needed in the Door wizard.
