Formula Help
Good Morning,
I'm trying to set up an Alert or two regarding tall cabinets and rollout shelves. Is there an "includes" or "contains" command that we can use in Microvellum? I haven't found anything that works. I'm trying to formulate something similar to what I have below but I don't know of any "includes" or "contains" commands.
IF(AND(Cab_Desc"includes or contains command","OCC",ROS_Qty<>0),"Double Check ROS Locations",0)
OCC is part of a cabinet code(but not the entire code) that we pass to the Cab_Desc Prompt so that part won't change.
Thank you!
