Hi
I am trying to use the local prompt for the drawer front heights (e.g Bottom_Drawer_Front_Height) within a drawer subassembly formula.
I am pushing the value "Bottom" through the prompt value column to a subassembly prompt called Drawer_Position.
I am then trying to use the value for L!Bottom_Drawer_Front_Height to use within a formula inside the drawer subassembly.
PARENTNAME(Drawer_Position&"_Drawer_Front_Height") does not work.
Is there another way around this?
Thanks
