Where Does one find the reveal settings and pull settings when using the "Master" with BAY ONE being a "Lift-Up".
As you can see from the attached the door pulls do not position properly in "Section View". However they are reflected properly in "Elevation View".
Also you can see that BAY TWO (beside the pull issue) does not set the door bottom reveal correctly.
